Frycleaner pro help
0 Members and 1 Guest are viewing this topic. Read 1235 times.
leo
Frycleaner pro help
« on: 4 Mar 2006, 03:18 am »
I have the main circuit board complete nothing else hooked up just the wire to L-M-H-V-DA-DK with power pluged in to  dc in .I have the board switch wired exactly like this-12 to H-11 to M-10 to L-  S to C to V to B-678 to DC in.Problem is the LED does not flash.And also where is the best place on the board to ground te DC in. help needed thanks Leo
hagtech
    • http://www.hagtech.com
Frycleaner pro help
« Reply #1 on: 6 Mar 2006, 07:37 pm »
Oh my, this is just as confusing as my original instructions.  Did you wire up the "S" terminal to rotary switch?  Without that, I don't think there will be output.
You can get ground anywhere on the board (any of the RCA jacks) or the hole next to "V".  See bottom of PCB to look for connections to ground plane.  See also the assembly photo downloadable from the web page.
Measure power to board using DVM.  Easy to check power pins of ICs.  LED has to be wired correctly with "+" to "DA".
jh
leo
Frycleaner pro help
« Reply #2 on: 8 Mar 2006, 04:51 am »
Thanks for the response.When I jump the switch the led does flash so I must have the switch hooked up wrong.I will cont. to trouble shoot..Leo
