0 Members and 1 Guest are viewing this topic. Read 6427 times.
Thanks for the tips, guys. I've only had the SB a few days so I'm in the really steep part of the learning curve.I'm not sure the cue files are in the same place as the main files. Maybe SlimServer can't find them. I'll try that. . .
All is not lost! When I mass-compressed my .wav files to .flac files, I went back to the .cue sheets and renamed the attached file ".flac" instead of ".wav". Voila - mass encoding AND .cue recognition.This is done in the text file editor in Windows. Thanks, Google.For now, the .cue and .wav files are showing up in the SB menu, which needs to be fixed somehow. At least I have functionality without disc-by-disc .flac encoding.
