B60 and 4 ohms
0 Members and 1 Guest are viewing this topic. Read 1469 times.
2 channel man
B60 and 4 ohms
« on: 28 Feb 2006, 01:27 am »
just wondering if any of you are using 4 ohm speakers and if you have
any thoughts or comments on it  , ie my amp runs cooler into 8 ohms
blah blah . I ran across a pair of Celestion A1's for a song they are 4ohm
rated I can not seem to find minimum impedance though.
elcaptain88
B60 and 4 ohms
« Reply #1 on: 28 Feb 2006, 01:41 am »
I owned a B60 for 2 years. It can drive most speakers out there to very high levels. I had the version previous to the SST update - so its likely even more refined now. Unless its a large room w/ concert level volumes - likely not a problem.
Phoenix
B60 and 4 ohms
« Reply #2 on: 28 Feb 2006, 04:01 pm »
I run the B60 with 2-Ohm Speakers (with very high sensitivity) - no problem here.
