DIY power cables????
0 Members and 1 Guest are viewing this topic. Read 1219 times.
2bigears
« on: 26 Feb 2006, 08:16 pm »
this may be over old ground here but i gotta ask,are the low cost power cables at least better than the factory ones.i hope so,cause i scooped some before asking???? :D  :D  :D  :D
Loftprojection
« Reply #1 on: 26 Feb 2006, 09:31 pm »
If you want very low cost and your equipment always stays at the same place, make yourself one with the same wire that is in the wall, a few feet cost almost nothing, the plugs at both ends can be a bit expensive depending on what you get.
« Reply #2 on: 26 Feb 2006, 09:34 pm »
Check out diycable.com 's power cable sale.  Cheaper than making them yourself :)
2bigears
« Reply #3 on: 26 Feb 2006, 10:16 pm »
MaxCast:that's what i did.two Asylums with the Exodus Red for the amp.i will test back and forth when they arrive.hoping they make a difference. :D :o  :o  :D
