Bryston Outboard DAC
0 Members and 1 Guest are viewing this topic. Read 1939 times.
rawbcca
« on: 25 Feb 2006, 09:13 pm »
James,
Any update on Bryston's plans to release a DAC ?
Any final decision on inputs/outputs ?
Price range ? Release date ?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 26 Feb 2006, 12:51 pm »
Hi,
Still working on the DAC - I would say another 2 months or so.
So far we are looking at SPDIF, AES,Optical and USB inputs.
james
Sebastiaan de Vries
    • http://www.soundevolution.nl
« Reply #2 on: 26 Feb 2006, 01:21 pm »
Dear James,
I hope the Bryston DAC wil involve the AD1896 samplerate converter. Not (only) for the upsample capability's but for the fact you can make a almost jitter immune DAC. This is in fact the power behind the so appreciated Benchmark DAC-1. Their so called ultra "ultralock" is based on the AD1896 in combination with the AD1953 DAC chip. The idea is simple. Buffer al the incoming (clock) data into a FIFO buffer (inside the AD1896 ARC). Then generate a new fixed clock frequency. for example if you upample tot 192Khz. 49251Mhz. in this case. The output of the AD1896 is fed bij a new stable clock.  Now there is no PLL anymore that have to be pulled by the wordclock generated by the digital source. (what always couse jitter no matter how stable or tight the PLL is) You have the most stable clock now close to the D/A converter chip, and there is the place where a stable clock is really important.
This is the main reason why the Benchmark sound so good. For the rest the opamps and the powersupply is nothing special and on the lowend side in the Benchmark. So my idea is, If Bryston use the same technology but with a real good powersupply and the great Bryston "DOA" discrete opamps. You might build the best dac currently availlible ;)
Powersupply is everything and I hope Bryston wil build some discrete regulator circuit for the important clock and dac ic's. Any way avoid a 7805 ;) :D
Best regards,
Bas
Sebastiaan de Vries
« Reply #3 on: 26 Feb 2006, 01:34 pm »
Dear James,
Even cooler. It would be so great if this DAC also have a seperate powersupply just like the BP26 ;)
Best regards,
Bas
« Reply #4 on: 26 Feb 2006, 01:37 pm »
The plan was that the DAC could be used with the MPS-2.
james
Sebastiaan de Vries
« Reply #5 on: 26 Feb 2006, 03:10 pm »
Quote from: James Tanner
james
Dear James,
I'm thrilled.. :D
Best regards,
Bas
