Beards
0 Members and 1 Guest are viewing this topic. Read 1466 times.
CornellAlum
Beards
« on: 24 Feb 2006, 12:21 pm »
What are you guys using for "beards" for 626r stands?  I would like to come up with something better than a piece of cardboard that looks halfway decent.  My idea is to chop up some 3/4" mdf I have in the garage, and stain it black, perhaps glass black to match the mls cabinets and use that.  Any other ideas which might be a little more asthetically pleasing?
John Casler
Re: Beards
« Reply #1 on: 24 Feb 2006, 11:08 pm »
Quote from: CornellAlum
Painted MDF should work fine.
CornellAlum
Beards
« Reply #2 on: 24 Feb 2006, 11:22 pm »
Thanks John, much appreciated.   :mrgreen:
Pocketchange
Beards
« Reply #3 on: 2 Mar 2006, 01:56 am »
A Larger works for me! :roll:
warnerwh
Beards
« Reply #4 on: 2 Mar 2006, 02:32 am »
You don't necessarily have to use a beard. You can also have a larger platform for the speaker to sit on so the woofer becomes augmented by the reflection just below it.  Something sticking out 3" would probably be sufficient.
