What 135W or more amplifier do you like?
0 Members and 1 Guest are viewing this topic. Read 1621 times.
rmihai0
« on: 23 Feb 2006, 08:41 pm »
What 135W or a bit more amplifier do you like?
My budget is limited to US$1,100.
Thank you
bhobba
Re: What 135W or more amplifier do you like?
« Reply #1 on: 23 Feb 2006, 10:38 pm »
Quote from: rmihai0
What 135W or a bit more amplifier do you like? My budget is limited to US$1,100.
Check out
http://www.avahifi.com/root/equipment/amplifier/omegastar_amps.htm
125W and 130W amps in your price range - the 5 or 10W shortfall would not be noticeable.  I rather like the at OmegaStar 240EX Amplifier at $899.
Connect it directly to a modded SB2/3 and watch out
http://www.audiocircle.com/index.php?topic=20939
Bill
john1970
Any of the NAD range should fit your budget
« Reply #2 on: 9 Mar 2006, 12:50 am »
I have the NAD C372 integrated amp (150 W min @ 8 or 4 ohms, 305 W dynamic into 4 ohms, 450 W dynamic into 2 ohms).  Most authorized dealers give a reasonable discount of the the suggested retail price of $900.  It sounds excellent and should be able to drive just about any reasonable speaker.
Dusty Chalk
« Reply #4 on: 9 Mar 2006, 08:52 am »
MF A3.2's?
skrivis
« Reply #5 on: 9 Mar 2006, 02:37 pm »
Quote from: bhobba
Quote from: rmihai0
Check out
Bill
I second the vote for the 240EX. They're well-built, well-designed, are very neutral, and the price is low. They're pretty much unbreakable in normal use too.
