What remote control options for this I would have...
0 Members and 1 Guest are viewing this topic. Read 3130 times.
Manolo
  • Consulting Structural Engineer
to use my laptop/usbfreeway with my dac? Thanks
Marbles
« Reply #1 on: 22 Feb 2006, 07:51 pm »
I use a Snapstream Firefly (usb on the receiver) for remote controlling of foobar2K.
It costs about $50.  It includes the remote.  You must have Win XP.
woodsyi
« Reply #2 on: 22 Feb 2006, 08:05 pm »
Quote from: Marbles
Excellent.  I should get one.  I am going to use my laptop to check things out.  Have you settled on a PC?
Marbles
« Reply #3 on: 22 Feb 2006, 08:27 pm »
Quote from: woodsyi
Yeah, I got a dual core 2.8mhz, 2 x 512 cache, dual 300 gig Seagate SATA HD's (not mirrored), an ASUS MB, a Zalman rheostat fan control (front of the case) for the case fan and the power supply fan, and a Zalman 9500LED chip fan/heatsink.  Antec Sonata II case.
Geoforce 6200 256M video card
Plextor DVD-RW
On board (ASUS) audio card.
Manolo
« Reply #4 on: 22 Feb 2006, 08:31 pm »
Thanks! Can it be configured to show a similar information window in the PC screen like in a CD player?-like track number time playing etc.. what about fast forward or rewind etc...?
Marbles
« Reply #5 on: 22 Feb 2006, 08:59 pm »
Quote from: Manolo
If you have ever used Foobar2000, that is the screen you will see.
The remote control has buttons just like a CD players plus others.
You can stop, pause, FF, play next track, play previous track etc...
woodsyi
« Reply #6 on: 22 Feb 2006, 09:04 pm »
Quote from: Marbles
Quote from: woodsyi
Plextor DVD-RW
That's a serious PC.  How quiet is it with the Zalman heatsink/fan controller when the disks are spinning?  I am going to try my lap top with WIFI card to see if I can access the music on .WAV files on my NAS box two floors up.  If it works and I like the sound (compared to SB2) I will build a quiet mini PC similar to a Hush or a Cappuccino to use with the off ramp.
Marbles
« Reply #7 on: 22 Feb 2006, 09:20 pm »
It sits about 25' from me and when I turn the fans down, I can't hear it.
It has so much ram that the drives don't seem to spin, or I can't hear them.
Even when I burn CD's to the HD's, the only thing I can hear is the Plextor drive spinning.
fu_man
SB vs USB offramp
« Reply #8 on: 23 Feb 2006, 06:52 am »
hey woodsyi,
will you keep us posted  regarding  your comparison  between  SB and   offramp?
woodsyi
Re: SB vs USB offramp
« Reply #9 on: 23 Feb 2006, 01:28 pm »
Quote from: fu_man
hey woodsyi,
Sure,
I will post something in an appropriate circle when I have had enough breaking in and listening to do a comparison.  Steve is building an I2S to be used with my Northstar 192 Dac which he is also modding.  It's a good thing he has my DAC since he had to build a new RJ45 terminated I2S cable due to different pin assignment.
Bear in mind that I am quite impressed with my fully modified SB2.  I think with modded analog section and PS, it is a great digital front end that rivals most highend units.  My modified digital out with silver Bybee was better than the analog out when fed to my Northstar DAC via S/PDIF, but I just kept thinking it could be better.  I never liked the Sony/Philips interface since it has to multitask all that signal simultaneously -- why I got the I2S Dac to begin with.  So, it just didn't seem right that I will only use the S/PDIF input on this DAC.  This of course led me to Steve and the I2S Off Ramp.  This is a fun hobby.  Isn't it?
fu_man
where there is choice there is misery
« Reply #10 on: 25 Feb 2006, 01:37 pm »
Steve has a fantastic  website.  I had intended to venture into using a comp. as  a music server  starting with  USB freeway.  I bought a  Xindak  DAC that was on sale locally and  was about to buy the USB Freeway when the I2s  option  became available.
I really wanted to go that route  but that would mean reselling the  DAC  before i had even plugged it in.
ultimately i decided to  start bit by bit, and the SB  allowed me to use my existing comp. and no need for  comp/monitor  etc in the listening room.  Steves gear is  so highly recommended I would love to know if i made the right choice.  i thought about getting the USB freeway anyway for comparison.. but  (financial  ) reality hit home.
I'm looking forward to getting my modded SB - but it  sounds like there is going to be  a fair wait.
