Tweak for your Sat DISH
John Casler
« on: 21 Feb 2006, 04:47 am »
Call me crazy, but my picture has never looked better.
First I did a "contact enhancer" (which will remain nameless since I am now a dealer) but I also tried a nother tweak that seems to have "turned my Sat DISH video quality up another notch.
My Dish is on my Patio and the other night, I was using a little PLEDGE (yep the furniture polish) on the vinyl coverings of my exercise equipment and thought "Maybe I should PLEDGE the DISH".
If nothing else it will clean it.
So I PLEDGED it , and PLEDGED it again since these dishes have a "dull" finish, maybe they are supposed to be dull, but damn if the picture doesn't look better than ever.
So don't climb up on the roof and fall off, but if the DISH is accessable, you might find a "good" PLEDGE treatment a nice tweak.
Let me know your results. :mrgreen:
F-100
« Reply #1 on: 21 Feb 2006, 05:52 am »
Hi John,
  You're not crazy but you do have some of the craziest tweaks that I've ever seen .:)
I'm going to try this tweak out tomorrow and will report my result.
Thanks.
Rom
« Reply #2 on: 21 Feb 2006, 07:35 am »
Hi John,
Your tweak really will work but only if your sat dish is a bit dirty,by cleaning it will improve your recieve level.
Besides it's always nice to see a clean dish.
cheers
rom
