0 Members and 1 Guest are viewing this topic. Read 16188 times.
bprice2: Getting the SB3 modded is a step in the right direction. I know that if you get it done you will enjoy it more than you do now. However if and when you do that you are stuck with what you have. I have an SB3 and love it. However I'm not getting mine modded. I'm going the outboard DAC route. I've got a DAC-60 with mods on order from GR Research. If I don't like it I can always try something else. If I get my SB3 modded then I have no way of trying out different setups. This is just my own opinion. ...
For now I chose to go with the external DAC. Probably down the road a bit I'll get my SB3 modded. But I'm thinking for now I'll wait a year or so before I have it done. By that time I'm sure a lot and I mean a lot of smart moddedrs will get involved and who knows what the results will be.
Of course, any individual may find one or the other option superior - without auditioning both you'd never know which alternative you prefer. But without audition, I would have to hear a bunch of arguments that using the DAC 60 out of a stock SB3 gave superior sonic performance to the analog mods to the SB3 before I would use that alternative. Infact, I'm planning to sell my DAC and my dejittering machine and my digital cables in favor of the analog mods to the SB3 explicitly because it is so much cheaper and casual reviews of the alternatives don't suggest that I'd be losing anything. (Besides, I want to buy a new pre-amp). ...
If all the things mentioned are correct, does it make any sense to: A) do the digital mod from Bolder for $120 B) order a basic power supply from Bolder for $230, & C) seek out an upgrade mod on the internal DAC in my receiver?
