Wire up LED in GK1
0 Members and 1 Guest are viewing this topic. Read 1217 times.
Felipe
Wire up LED in GK1
« on: 20 Feb 2006, 12:13 am »
Hi,
Can anyone tell me where to wire the front power LED for the GK1 ?
Can i use the 17V AC directly from the transformers ?
AKSA
Wire up LED in GK1
« Reply #1 on: 20 Feb 2006, 03:11 am »
Felipe,
You can wire up a power LED for the GK1 from the positive power supply of say the left channel SS section.
This is at +14.4 volts +0.6, -1.
If we assume 14.4V and a LED voltage of 2, and gun for say 3mA, then the dropper resistor from the positive supply to the anode of the LED will be (14.4 - 2)/0.003 = 4133R.  Nearest preferred value would be 3K9, giving a current of 3.18mA, near enough for government work.....
The kathod of the LED would be directly connected to preamp earth.
Hope this helps,
Hugh
