B60 speaker suggestions
0 Members and 1 Guest are viewing this topic. Read 2212 times.
2 channel man
« on: 18 Feb 2006, 11:58 pm »
Hello everyone :D
I am the owner of a Bryston B60 and I'm lookin for some speakers
either bookshelf ( I have 26" Apollo stands w leadshot)  or small towers
is fine but hers the catch I own 2 other amps Anthem Int 1 25Wx2 tube
and a Myryad MI 120  60Wx2 and I like some made in CANADA the U.K.
and the U.S.A. right now the ones that have caught my ear are Energy
RC-30 and RC-50 ( although A&b sound couldn't set em up right if lives depended on it !)
 B&W 603 , 604 , I haven't listened to Totem yet (also
at A&B ) I did like the Energy Rc30 although under less than ideal setup.
But I want feedback from fellow B60 users
jethro
« Reply #1 on: 19 Feb 2006, 12:32 am »
I doubt that you have enough power for the 603 and 604 to really make them shine. I don't have a B-60, but I have found that the B&W's work really well with Bryston amps - not as good as PMc, but quite good. I have 2 sets of B&W 600S3 and I love these speakers for small rooms. You might want to have a listen to this model as well if they still make them.
julian
« Reply #2 on: 19 Feb 2006, 08:29 pm »
I use my B60 with Harbeth HLP3ES2s. These are relatively low in sensitivity but will go loud enough for me. Harbeths are famed for telling it like it is and I think that's a fair summation; as far as is possible they add nothing and conceal nothing - much like the Bryston sound I feel, a window on the recording. Check out the Harbeth web site http://www.harbeth.co.uk.
WEEZ
« Reply #3 on: 20 Feb 2006, 11:15 pm »
PMC TB2+ would likely be a great match.
WEEZ
