Illuminati Datastream Digital Coax -- anyone familiar?
0 Members and 1 Guest are viewing this topic. Read 1269 times.
krikor
  • Initiative comes to those who wait.
    • AudioSnoop.com
Back when I had a two-box digital system I bought this coax digital cable. That was nearly 10 years ago and since I've since gone to a single box solution, I've had it stashed away in a box.
Very strange design ... it is has a solid casing for the ground that you bend to fit the distance between your transport/dac. The connectors are solid machined and supposedly perfect 75 ohms (+-0.5).
Anyone else out there familiar with this cable? Is it worth anything?
Feisal K
    • DVD-A registry
Re: Illuminati Datastream Digital Coax -- anyone familiar?
« Reply #1 on: 19 Feb 2006, 11:42 am »
Quote from: krikor
must be only me that found this somewhat ironic.  :lol: [/b]
RichardS
« Reply #2 on: 19 Feb 2006, 01:17 pm »
This cable was designed by Chris Sommovigo (of Stereovox). One of the (if not the) first cables to be designed specifically to meet the needs for S/PDIF transmissions (ie, reduce reflections).
see:
http://www.tnt-audio.com/accessories/digitalcables_e.html
