Biamping with SS and tubes question
0 Members and 1 Guest are viewing this topic. Read 1009 times.
warnerwh
« on: 17 Feb 2006, 05:23 am »
I'd like people who are doing this to give me thier opinion on how the sound is at various volume levels.  I'm thinking of trying this with my Vmps RM 40's but am concerned that running two different brands of amplifier will have different sonic characteristics and possibly not stay aligned with one another at different volume levels.
« Reply #1 on: 17 Feb 2006, 12:37 pm »
I think you have to be concerned with in/out impeadances of each amp with the pre and the gain of each amp.
woodsyi
Re: Biamping with SS and tubes question
« Reply #2 on: 17 Feb 2006, 02:38 pm »
Quote from: warnerwh
Warner,
The only thing that doesn't stay aligned is your wallet.  :lol: If you set it up right, you get the best of both ss slam and tube magic.  I don't hear any drop off at high volume and I can listen as softly as I want.  At one of the meets, we had my 40s rocking at 105 db for a few songs and only thing rattling was my Scotch bottles next to the subs.
ESL amp should drive the woofers on the 40s real tight.  I put in a CJ SS after I pulled the Innersound amp (to drive my Soundlabs).  It wasn't good -- I ended up getting a pair of eAR 1001s to do the woofer duty.  Now it's good.  Nuforce should be good too since it has such high damping factor.
I tried passive biamping first but gave up after having to use an attenuator on my ARC VT100.  By the time I got the levels matched, all the magic on the tubes were choked up.  :evil: In came the activecross over and fun with all kinds of amps and interconnects.  You don't need all that.  RM 40s have complete passive filters on the ribbons.  You can run the ribbons straight out of your preamp output.  All you need is a low pass filter on your woofers.  I would get a subwoofer crossover (must be able to to up to 280 Hz) with room eq capability.   With CDWG the total output of ribbons is reduced and actually helps in leveling the field with the woofer output.  All you have to do to go active biamping is to desolder and disconnect one end of the inductor in your 40s.  I have run 28W, 40W, 100W, 125W and 200W tubes on the ribbons to sucessful outcome.  I am currently "stuck" on a 125W triode magic. :wink:
ricmon
« Reply #3 on: 17 Feb 2006, 02:42 pm »
Simlper is always better.  JMHO
woodsyi
« Reply #4 on: 17 Feb 2006, 02:46 pm »
Thanks for your insight, Ricmon.  Are you free March 11th?
R_burke
« Reply #5 on: 17 Feb 2006, 03:38 pm »
I use a Sonic Frontiers Power 2 along with an ADCOM GFA 5800 to power my Innersound ISIS.  This set up works very well for me, but the ISIS is a hybrid, which I think lends itself to this kind of bi-amping better than most.
I have no problem with consistency across volumes and love the sound of tubes with Electrostats without the loss of lower end due to the woofers being powered by the GFA
Gordy
« Reply #6 on: 17 Feb 2006, 04:17 pm »
Quote from: woodsyi
There is no single answer, eh?  Stop on by if you can Ricmon, Woodsyi's system is a wonderful listen!!!
flintstone
bi-amp
« Reply #7 on: 17 Feb 2006, 04:21 pm »
Rogue Audio M-120 magnums would be worth checking out...I have a pair driving my Apogee Duetta Signatures. I also own Krell and Vmps...the Rogues are a good mate with SS amps...ie, the balls of solid state while having the midrange magic of tubes. You'll need an active crossover I'll guess.
Dave
