bugle problem Help!
0 Members and 1 Guest are viewing this topic. Read 1213 times.
gta
bugle problem Help!
« on: 16 Feb 2006, 12:25 am »
Hello everyone i changed the caps in my bugle to pio caps that i had on hand all values stayed the same except the two .01 i only had .05 on hand so i used these now i have lost high frequencies it sound like a blanket is on over my speakers very muffled do you think using the wrong values for the 2 .01 caps caused this and if so what value would you reccomend to sub for  .01 caps. thanks in advance
hagtech
    • http://www.hagtech.com
bugle problem Help!
« Reply #1 on: 21 Feb 2006, 04:05 am »
Was it working before?  Usually what happens is that one of the new caps has the wrong value.  Sometimes the printing on the caps isn't clear (0.01uF or .001uF?).
jh
