mm decapo i or triangle antal
0 Members and 1 Guest are viewing this topic. Read 2509 times.
socrates35
« on: 15 Feb 2006, 12:38 pm »
hi, i am from turkey. i use that equipment:
quad cd-p 99 cd plyer
audio note an-vx interconnect
d&b lab m80 triode tube power amp pushh pull
audio note an-spe speaker cable
triangle antal es speakers
project debut mkIII turntable-audio technica at440ml cartridge
vibrapod cones ve isolators
   i want change my antal es speaker to with mm decapo-i. may you make comments? thanks for all
note: i am listening rock %40,classic %30, jazz %20, and others.
socrates35
Re: mm decapo i or triangle antal
« Reply #1 on: 28 Jun 2006, 10:19 am »
i bought mm decapo-i . my old speakers triangle antal single good but bad stereophonic efect . mm decapo-i is good soundstage, natural and very detailed.
