Burning DVD from A Camcorder
0 Members and 1 Guest are viewing this topic. Read 1664 times.
John151
« on: 14 Feb 2006, 05:00 am »
A friend, who is travelling on business, emailed me that his daughter has a school project that she needs help with.  She needs to burn a DVD from her camcorder.  The father gets in Wed night, and the project is due on Thursday, and I don't have any details about the camcorder, or any of the availalbe PCs.  I realize that I don't have enough details to allow for a decent answer, but I am hoping to get some background and general suggestions.  Any thoughts you have on this matter will be greatly appreciated.
Thanks, John
  • Speakers....What Speakers ?
« Reply #1 on: 14 Feb 2006, 05:33 am »
John...I don't have a clue :? ....but I did find this.... http://www.microsoft.com/windowsxp/using/moviemaker/expert/jones_02november25.mspx  ...maybe it will help. :D
John151
« Reply #2 on: 14 Feb 2006, 05:45 am »
Quote from: lonewolfny42
That article is spot on.  Thanks!
F-100
« Reply #3 on: 14 Feb 2006, 05:52 am »
Since time is a critical issue and you don't have any info on the camcorder (analog or digital??), I would suggest your friend this simple quick and easy method . Go to Best Buy or Circuit City and buy one of these DVR recorders. You don't need to buy any additional software, just plug-and-record. :)
http://www.bestbuy.com/site/olspage.jsp?skuId=7567509&type=product&productCategoryId=pcmcat13900050019&id=1130987443557
http://www.bestbuy.com/site/olspage.jsp?skuId=7032784&type=product&id=1099395252109
jqp
« Reply #4 on: 15 Feb 2006, 03:53 am »
If you have a Sony camcorder, I would recommend the GX315 which BB also sells.
-you can burn to dual-layer disks
-burning from camcorder via firewire (the superior way) is a 1 step process, and you can edit on the fly (you can use it as if it were a VCR for that function)
-no pesky program guide to get in the way
-tuner is flawless - no mono/stereo problems
This is not a cheap quality, unreliable player, nor is it inexpensive, but I think with rebate is is less than $250.
I use it for making DVDs from my camcorder about once a week.
