samplesj, do your PRs fire to the rear?
0 Members and 1 Guest are viewing this topic. Read 1516 times.
kroberts1972
« on: 13 Feb 2006, 08:05 pm »
Jeremy,
I found a picture of your room and I can see that the speakers seem to be forward firing, and I am assuming your PRs fire to the rear.  Is this correct? I am limited on depth to about 18" but I can go about 4' wide and 4' tall.  I was thinking of doing  2 forward woofer and s side firing PRs stacked on top of each other.  Does this make sense?
samplesj
« Reply #1 on: 13 Feb 2006, 09:49 pm »
Yes, I have the drivers forward and the PR on the back.  It is just Danny's example box doubled with a single shared wall.  I need to get some pictures of the new box up and get rid of those old ones with the PE vinyl wrap.
I'm not really a good resource for alternative box designs though.  I've got a copy of bassbox lite, but in the end I had enough questions about box design, that I just played it safe and used his design.
I've seen a couple of other box designs on this forum.  If you are talking about two stacked cubes with the driver and PR at 90degrees to each other than I know several people have done that.  Actually all of the pictures Al at RAW used in your screw thread are that design.
kroberts1972
« Reply #2 on: 13 Feb 2006, 11:20 pm »
Thanks Jeremy, I saw his post after I asked you the question.  That 4 sub tower looks imposing.
RAW
« Reply #3 on: 14 Feb 2006, 12:49 am »
Yes that sub tower does look good!
Now that is all in a room with a pair of Alpha's.
Yes count them a total of 8 of the SW12 drivers in a room.
 :drums:  :beer:  :rock:
