SW12A/PR12A downfiring sub
0 Members and 1 Guest are viewing this topic. Read 2581 times.
kroberts1972
« on: 12 Feb 2006, 08:53 pm »
Hello All,
I want to build a sub with 2 SW12A's and 2 PR12A's by creating a cabinet that is double the cabinet shown in the PDF on the GR-Research website.  Would this configuration make sense to have the woofer downfiring and PR upfiring or vice verse?  If not, what would be the best configuration for a tall sub?  I have depth for a 33" wide 16.5" deep 22" high sub, but not for a 22" deep sub.
Thanks in advance,
Kevin
Danny Richie
« Reply #1 on: 12 Feb 2006, 10:44 pm »
I just recently built a dual sub cabinet myself that is just like the plans on my site but for a pair using a common wall. I still need to veneer it.
You can down fire the sub if you like, but the heavy PR needs to be mounted vertically on one of the sides.
gitarretyp
« Reply #2 on: 12 Feb 2006, 10:45 pm »
You can't have the PR firing up or down --too much weight on it. You could put one woofer down, one up and put the two PRs on the one of the sides.
kroberts1972
« Reply #3 on: 12 Feb 2006, 11:19 pm »
Thanks for the quick replies, I am glad I asked before doing.  Does it matter which side the PRs are firing toward?  For instance, If I the cabinet near a corner, should the PR's fire toward the room or toward a wall?
Kevin
Danny Richie
« Reply #4 on: 12 Feb 2006, 11:26 pm »
It will make a difference which way they face, but there is no wrong way. You will like one way more than another.
kroberts1972
« Reply #5 on: 12 Feb 2006, 11:39 pm »
By the way Danny, is this amp at PE the same as the the Apex Senior?
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-794
I need some other stuff at PE, and it is a little cheaper.
Danny Richie
« Reply #6 on: 12 Feb 2006, 11:45 pm »
That amp is made by the same company but it is a smaller version (less powerful).
kroberts1972
« Reply #7 on: 12 Feb 2006, 11:51 pm »
I will have to order the Apex then.  You will be getting an order from me soon.  Thanks for the help!
Kevin
