Multiple music directories with sb
0 Members and 1 Guest are viewing this topic. Read 1120 times.
randytsuch
« on: 8 Feb 2006, 02:40 am »
I remember reading a post a while ago (which I can't find anymore) about someone complaining you can't have multiple music directories with slimserver/squeezebox.
But, you can, and it is actually easy.
First, go select the other directory (the one that is not pointed to in slimserver), and right click it, and select create shortcut.  This will make a shortcut to that directory.
Now, copy the shortcut into your music directory, rescan and the directory will now show up.
You could also use this over multiple hard drives.
If this is common knowledge, then you can ignore, but I just figured it out today.
Randy
Thump553
« Reply #1 on: 8 Feb 2006, 07:46 pm »
Great tip.  I was actually wondering how to do that myself just last night.  I thought it might be something like you described but that seemed a bit inelegant.  Hopefully as slimserver matures they will build this into the coding.
