0 Members and 1 Guest are viewing this topic. Read 11992 times.
The material that was linked to is 8lb/cu ft density. This, IMO, is not acceptable for side wall reflection point usage. It's too dense and will actually case higher frequencies to reflect when hit at shallow angles - like you'll get on a wall for the sides. For bass control in the corners, it's a fine product.
I use........4 inch stacked 1 sq ft in 8ft tall corner columns. No more bass issues
All of the mineral wool boards I saw were 8lb.For reflection point duty, 3lb is really much more appropriate. OC703 is the defacto standard - or 3lb acoustical cotton if you want a green product that performs better - but at a higher price.If you're set on buying only a single product for both applications, get 703. You can use 6" of 703 and it will outperform 4" of 705 (6lb) straddling a corner or even flat on a wall.Also, as was stated, watch the shipping costs. Many places blast cheap pric ...
8/5 = 160%......therefore 8pcf is 60% more dense than 5pcf8/3 = 267%......therefore 8pcf is 167% more dense than 3pcf5/3 = 167%......therefore 5pcf is 67% more dense than 3pcf
8#5#3#is short hand for8.0 PCF5.0 PCF3.0 PCFPCF = Pounds per Cubic FootThe higher the number the greater the density. Therefore 8.0-PCF is 37.5% more dense than 5.0-PCF and 62.5% more dense than 3.0-PCF.While 5.0-PCF is 40% more dense than 3.0-PCF
...............Therefore 8.0-PCF is 37.5% more dense than 5.0-PCF and 62.5% more dense than 3.0-PCF.While 5.0-PCF is 40% more dense than 3.0-PCF
