Echoes still available?
0 Members and 1 Guest are viewing this topic. Read 2181 times.
Jason Nugent
« on: 6 Feb 2006, 05:14 pm »
Greetings,
I'm getting to the point in my room construction where it's time to start thinking about acoustical treatment.  I read a review of your products here:
http://www.audioasylum.com/audio/general/messages/261239.html
And the author mentions an "echoes" wall product, presumably for taming first order reflections and slap echo.  I can't find it on your website, though.  Do you still offer it?
Best regards,
Jason
8thnerve
« Reply #1 on: 7 Feb 2006, 07:11 pm »
The Echo product was discontinued because a Seam can be used to much better effect in the same place.  We recommend 8 Seams and 4 Corners as a standard package now, and the performance is much improved over the older RoomPack combination.  Feel free to email me pictures of your space to [email protected] and I would be happy to make a custom recommendation for you.
Jason Nugent
« Reply #2 on: 7 Feb 2006, 07:26 pm »
Thanks for the answer.  Email sent.
regards,
Jason
