FB1 Upgrade to FB1+
0 Members and 1 Guest are viewing this topic. Read 1558 times.
kas
FB1 Upgrade to FB1+
« on: 5 Feb 2006, 08:23 am »
I have been thinking about upgrading my FB1s to the Plus version and was wondering if it is worth it. Also I was told by my Authorized Dealer that he can do the upgrade! I am concerened about the accuracy and competence of his job, since the transmission line will have to be upgraded too. I don't think that he will test the speakers similar the same way any FB1+ is tested before leaving the factory. Should I have these concerns? I would like to hear from anyone who had his/her speakers upgraded by an AD and if they're satisfied with the workmanship.
kas
dan_lo
FB1 Upgrade to FB1+
« Reply #1 on: 7 Feb 2006, 11:39 am »
Hi kas,
The upgrade is very worthwhile in my opinion.
About the dealer performing the upgrade: No problem. It's a very simple procedure. I did it myself at home, and I am no expert.
