Tamnnoy
0 Members and 1 Guest are viewing this topic. Read 1526 times.
Jos
Tamnnoy
« on: 4 Feb 2006, 05:28 pm »
Hello Jason,
I'm considering demoing the ref.9's plus your pre-amp but I am not sure whether they will match with my Tannoy 15 DMT MKII speakers. They have a sensitivity of 98 dB, impedance 8 Ohms. What do you think?
Best regards, Jos
rustydoglim
    • www.nuprimeaudio.com
Tamnnoy
« Reply #1 on: 4 Feb 2006, 08:06 pm »
In that case, go with Ref 8.5 which is Ref 9 with a 100W power supply.
If you need more power later, Ref 8.5 can be transformed into Ref 9 with a change of power supply and face plate.
