RS-232 Codes for SP-1, SP-1.7 and SP-2?
0 Members and 1 Guest are viewing this topic. Read 1572 times.
mv038856
« on: 4 Feb 2006, 03:50 pm »
Hi James!
I was wonderng where to find the RS-232 codes for the SP-1(PRO)!?
On the Bryston web site I found some documentation for the SP-1.7, but neither the SP-1, nor the SP-2 are mentioned. Someone asked the question about the SP-2 codes (whether they changed from the SP1.7) in another tread, but I couldn't find an answer there.
I recently acquired a Crestron Processor and adapted the user module provided for the SP 1.7 on the Bryston web site. However, the only commands that seem to work on my SP-1 are the power up and the power down...  :(
I am planning to upgrade to the SP-2 anyway, but I want to find out whether the SP-1 not working with that particuar software version is due to not supported RS-232 commands, a RS-232 communication problem  or my programming expertise...  8)
Markus aka mv038856
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 5 Feb 2006, 07:53 pm »
I will check with Mike Pickett on this one.
james
mv038856
« Reply #2 on: 9 Feb 2006, 10:24 pm »
Hi James!
Did you get the chance to ask Mike about the RS-232 codes?
Markus
« Reply #3 on: 9 Feb 2006, 10:30 pm »
Quote from: mv038856
Hi James!
Markus
The SP2 codes are, for the most part, identical to the codes for the SP1.7.
Here's a link to the 1.7 codes:
http://bryston.ca/pdfs/SP17_RS232_051.pdf
At some point we will publish a complete protocol for the SP2 including any changes, if applicable, and post it on our website.
Mike Pickett
Engineering Technician
