SB2 - Flac vs. Wav
0 Members and 1 Guest are viewing this topic. Read 2626 times.
jkelly
SB2 - Flac vs. Wav
« on: 3 Feb 2006, 01:32 am »
I pretty much accepted that FLAC was identical to WAV in the RWA SB2 player.  The flac decompresses to wav and thats that.  However have you ever loaded a folder with a identical set of songs in FLAC and wav files?  Now this could be the way my flacs were made but I am consistantly hearing slightly more velvety sound and more harmonics in the wav versions. The FLACs are slightly more edgy and electronic.  I want to say you really have to listen hard for this.
I am using the Clari-T with SAS IC's that are very revealing and all lights out with eyes closed to hear this.  This setup is like an audio microscope!
Has anyone done a comparison and noticed any difference in a back and forth comparison of the 2 file formats?  It might be my flacs.
Jeff
dwc
SB2 - Flac vs. Wav
« Reply #1 on: 3 Feb 2006, 01:50 am »
Why don't you try having your flacs decoded to wav on the server side?  Now you have a third sound to mix into the comparison.  Please remember to have someone switch the streams for you without telling you which type you're listening to.
-Dan
Jon L
Re: SB2 - Flac vs. Wav
« Reply #2 on: 3 Feb 2006, 02:29 am »
Quote from: jkelly
I am using the Clari-T with SAS IC's that are ...
I highly recommend you teach somebody to flip back and forth between Flac and wav while your eyes are closed.  See what your correct % is....  When I tried this with .wav/Flac/apple lossless (re-encoded to Flac), it sure was an enlightening experience.
jkelly
SB2 - Flac vs. Wav
« Reply #3 on: 3 Feb 2006, 02:57 am »
Good idea - I will let someone else drive and see what I get.
Jeff
Paul_Bui
  • Rode NTK and S-1 microphones
SB2 - Flac vs. Wav
« Reply #4 on: 3 Feb 2006, 05:31 am »
Jeff,
Nice to learn that you have the same gear and ear as mine.   Oops, almost.  Your speakers are BB FT-1600MkII, and mine are BB FTA-2000s.  Same family anyway.
DSK
« Reply #5 on: 3 Feb 2006, 06:11 am »
Quote from: jkelly
...Now this could be the way my flacs were made...
How were they made, Jeff ...via EAC?
DSK
SB2 - Flac vs. Wav
« Reply #6 on: 3 Feb 2006, 06:12 am »
Quote from: dwc
Why don't you try having your flacs decoded to wav on the server side? ...
Have you tried this, Dan? What were your findings?
jkelly
SB2 - Flac vs. Wav
« Reply #7 on: 3 Feb 2006, 12:59 pm »
I used EAC to create the Flacs.
Jeff
ctviggen
SB2 - Flac vs. Wav
« Reply #8 on: 3 Feb 2006, 01:06 pm »
How did you get the wav?  With EAC also?  Do you use EAC to create the wav and then use the FLAC program to create the FLAC?
jkelly
SB2 - Flac vs. Wav
« Reply #9 on: 3 Feb 2006, 04:29 pm »
Quote from: ctviggen
Yes - I did use the FLAC program to re-create the WAV.
This whole thing came about as an accident.
I made a test cd for a friend of some selected songs and needed to make wavs to burn the cd.  (I don't have a flac cd program yet).
So I used FLAC to create the wavs.  Again I am (still) under the impression that FLAC is like a zip of wav's.  Restores bit accurate when decompressed.
After I "let him borrow" the cd, I wanted to hear it and since I don't have a cd player in the system I pointed slimserver to the folder where the flacs and wav reside.
Listening to the first 15 sec of the 2 versions, back and forth, back and forth, got me to make this post.  That was my first impression anyway.
I don't understand how SB2 works with flac.  Does it just play them natively?  Does it decompress realtime? Does it decompress the entire file to a buffer?  That is where I am heading - not about the FLAC format but does the SB2 suffer at all from the decompression.  As mentioned above, switching to server decompression will be a good test.
BTW I am running V.15 firmware.
This weekend I will do some further listening.  I guess I am asking if anyone has actually A/B'd the 2 file formats?
Jeff
ctviggen
SB2 - Flac vs. Wav
« Reply #10 on: 3 Feb 2006, 04:56 pm »
I haven't tested the two formats but might now that you have.  I'll see if I can reproduce the results.  I might not be able to do this for a while, though.
Folsom
SB2 - Flac vs. Wav
« Reply #11 on: 3 Feb 2006, 05:06 pm »
While I have not been comparing them for the sake of comparrison, I have to say .FLAC has been a little better for me.... I have no idea why just .FLAC files are not as quiet it seems like to me. I know this makes no sense  :lol: .
dwc
SB2 - Flac vs. Wav
« Reply #12 on: 3 Feb 2006, 05:51 pm »
Quote from: DSK
Quote from: dwc
It's very easy to try this, by simply checking and unchecking a box on the file types page.  If you check the box that says FLAC-WAV, then the server will decode before streaming.  If you uncheck that one and leave FLAC-FLAC checked, then the server streams FLAC to the SB and the SB decodes it locally. Restarting the test song plays it in the new stream.
I tried one evening to tell a difference, and thought that I could.  I'd bet money though, that I'd fail to be able to discern the difference in a blind test.  Nonetheless I have left the server streaming wav files out of superstition, and to reduce processing on the SB side.  The cost is a higher bandwidth load on the wireless network, and not being able to FF or rewind  inside a song.  If my network ever were to barf or if I were to try running from a weaker box (like a nas device)  I'd switch back to native flac
-Dan
