How thick of OC 703 for corners to impact bass?
0 Members and 1 Guest are viewing this topic. Read 7750 times.
CJ Paul
« on: 2 Feb 2006, 06:30 pm »
OK, I have a local source for Owens Corning 703 rigid fiberglass.  How thick should I use for corner panels?  I'm thinking of doing (2) 2 x 4 panels in the corner plus (2) triangles in the 3-way corner where the corner of the walls meets the ceiling.  What thickness should this be to act as bass traps.  Also, if money is an issue, would you treat for bass first or reflection points for high/mids first?
Also is $9 a 2x4 sheet of 1" thick 703 a good price?
bpape
    • Sensible Sound Solutions
« Reply #1 on: 2 Feb 2006, 06:59 pm »
$9 for 1" is kind of high for a local price.  You should be able to get 2" for that.
With 703's lower density (3lb/cu ft), 4" min - 6" recommended for good solid bass absorbtion down relatively low - straddling the corner.
CJ Paul
« Reply #2 on: 2 Feb 2006, 07:17 pm »
OK, I was quoted 1.14 per square foot.  Each sheet is 8 square feet.  I think I found the only local distributer of OC that sells to the public.  I did find this place a while back though (http://www.insulationworld.com/prodList.asp?idcategory=36&curPage=4&sortField=price) and their insulation is 8 pounds per cubic foot, so I assume I could get by with less thickness?
Is there a different model number of OC that is denser?
Carlman
« Reply #3 on: 2 Feb 2006, 08:06 pm »
OC705 is a 5 lb. density.
Using OC703, 2 2" boards sandwiched to make 4" is the standard most people use for bass traps.  I've never heard or seen 6" used in all the case studies on the web.
I paid $1.20 per sf for 2" OC703 w/ a foil facing.
Glenn K
« Reply #4 on: 2 Feb 2006, 11:51 pm »
Quote from: Carlman
As I don't want this to come off as advertising, really I do not, but I think I can shead a little light on the 4" vs 6"
Our last lab run  for the 244 (4"), "J" testing, straddled in corner
Absorption Coefficient
50hz  .58
63hz  .78
80hz  2.02
100hz 1.85
125hz 1.64
Now a new trap that is 6"
50hz .63
63hz 1.27
80hz 3.00
100hz2.34
125 hz 2.00
I think it is pretty clear that if you want to smack the low end then use 6".. BTW, the number for 6" beat not only on the low end but also the high end, way more then what we thought it would..
Glenn
tdangelo
« Reply #5 on: 3 Feb 2006, 12:16 am »
Glenn,  are you going to make your panels using the 6" material?
Tony D.
richlo
« Reply #6 on: 3 Feb 2006, 05:25 am »
Quote from: tdangelo
Tony D.
Actually I bought 2 of the 2x4 7.5"thick :o  panels from him, that I took receipt of yesterday evening...they are the 247 model not posted on the site..
  :mrgreen:  MUY ALEGRE!!!
bubba966
« Reply #7 on: 3 Feb 2006, 05:30 am »
Quote from: Carlman
Carl, I've used 6" of 703 as floor to ceiling bass traps before. Worked rather nicely I must say...
Glenn K
« Reply #8 on: 3 Feb 2006, 12:45 pm »
Tony D.
Yes, but not to get off the subject, please just email me for info...
Carlman
« Reply #9 on: 3 Feb 2006, 01:40 pm »
OK so I do a few months of research and track down the OC703, buy it, and then find out I don't have enough.
......Gee thanks... ;)
Thanks for the research, Glenn... :) Sharing research results is what this forum is all about... and definitely not considered advertising.
CJ Paul
« Reply #10 on: 3 Feb 2006, 02:21 pm »
There is a photostiched picture of my room.  As you can see, the left corner is by the stairs that come down.  Would you still threat the left and right corners identically as if the room were semetrical?
CJ Paul
« Reply #11 on: 3 Feb 2006, 05:45 pm »
I just found a local source for some rock wool.  Its 8 pound per cubic foot and its $30 for six 2'x4'x2" sheets.  I think I'm going to pick some up.  Does anyone have a response to my picture?
Red Dragon Audio
    • http://www.reddragonaudio.com
« Reply #12 on: 3 Feb 2006, 07:53 pm »
Quote from: CJ Paul
I'd say pick up a 2-3 boxes (I presume that each box contains 6 sheets).
That's a fantastic bargain for the return you'll certainly get on your money.
This will give you more panels to experiment with in your room.
By the way I'm jealous of what looks to be a pair of stereo mounted dual IB subs...  :mrgreen:
CJ Paul
« Reply #13 on: 3 Feb 2006, 08:08 pm »
 That's what it is.  My room is 24'x38' so I need a lot of sub...
Glenn K
« Reply #14 on: 3 Feb 2006, 08:55 pm »
Quote from: Carlman
Thanks, but don't let me tell you  4" would not work also.. If that is what you have then I would use it.. I don't want to start a new 6" standard YET!!!!! ha ha ah
Glenn
ryanallen
« Reply #15 on: 3 Feb 2006, 11:08 pm »
Quote from: CJ Paul
Looks like you can still mount a trap in that corner by the stairs.  But to answer your question, a trap can be mounted in any corner not just wall/wall corners.  Try wall/ceiling or wall/floor combos as well.
Inscrutable
    • http://home.earthlink.net/~inscrutabl/index.html
« Reply #16 on: 3 Feb 2006, 11:38 pm »
Not to hijack your thread CJ, but what the heck - I know you thrive on abuse  :wink:  I found this thread on resonance/absorption by different wall systems interesting, and since we're talking thicknesses and densities and measurements ... oh my! ... yeah its a bit of a stretch.
http://www.avsforum.com/avs-vb/showthread.php?t=638531
richlo
« Reply #17 on: 4 Feb 2006, 02:35 am »
Quote from: CJ Paul
YEAH - We all know you from Hometheatertalk...there is a CULT IB going on over there :evil:
I WANTS ME SOME IB>>IWANTS ME SOME IB :lol:
Carlman
« Reply #18 on: 4 Feb 2006, 02:12 pm »
Quote from: Glenn K
Quote from: Carlman
Glenn
Oh, but you have!  I went and bought more OC yesterday... So now I have enough to do 6" panels from ceiling to floor in the corners... and enough for the wall behind my head, and primary reflection points.
I still can't get over how stinky they are... I didn't see that tidbit anywhere in my reading either... ;)
So, if I add the extra $55 to my project, I'm around $300 for a fully treated room including all materials.  Not terrible.
-C
richlo
« Reply #19 on: 4 Feb 2006, 05:36 pm »
Quote from: Carlman
-C
Let us know how it impacts your room...how does it sound to you..
