0 Members and 1 Guest are viewing this topic. Read 7905 times.
All, I have to thank people who pointed me to this mineral wool alternative. Previously I have been looking all over Houston trying to find Owens Corning and Knauff fiberglass board but unsuccessful. I have managed to find IIG mineral wool product this morning though. The question I have is given this IIG MinWool-1200 pipe has density of 8lb, What would be the minimum thickness that I should get? And do I need different thickness for 1st reflection point vs using as bass trap at 4 corners? Thank you very much. RV
Thanks guys.. one last question, is there a particular type of fabric that's good for wrapping up these Mineral Wool materials?Jon Risch mentioned that he prefers Burlap, but I thought Burlaps have some large gap between the threads hence it's not good enough to prevent the mineral wool from coming off. I went to Walmart and saw some 100% Polyster fabric, thicker than most fabric and have no gap at all, is this a good choice?
This is just an opinion but I think you should use either an open weave cotton or wool. Think about something on the lines of cheese cloth. My pea brain reasons that cotton and wool provide a (very) minor amount absorption and will also allow the sound waves to freely pass into your mineral wool. If you go with a synthetic blend such as polyester, with it's composition and weave density, you will likely get reflections off its surface. .... but then again, I' might be all wet.
