0 Members and 1 Guest are viewing this topic. Read 8580 times.
QuoteSounds like calculator time for you. Sorry, this one should be simple math. Thats fine if you are good at math...Me ? Not so good
T/S parameters are remarkably accurate at capturing the small signal performance of a driver. Krutke is not "some guy on the Internet"... he's a professional engineer, just as Dan Wiggins is. This is science, not a popularity contest. No need for personal attacks on either person; it adds nothing to the discussion. The reality is that Adire's numbers are suspicious. Take a look at their own posted impedance plot: http://www.adireaudio.com/Home/Images/ExtremisZ.gif Notice how the impedance peak measured by Adire is around 37Hz, exactly the same as what John Krutke measured. Why, then, does Adire claim a Fs of 30Hz? Adire's claim, using their own measurements, doesn't make sense. Perhaps reality takes a back seat to marketing.
All parts of this test are done with Soundeasy 10.0. This is a modeling package with a lot of extra testing applications included. It is not a full acoustic measurement system such as CLIO or Praxis however, so take these results with a grain of salt. What is important however is that all of these drivers were tested in the same way. Because of this, my test results should not be compared with tests done elsewhere by other people, but comparisons within this group of drivers are perfectly valid. That's why tests like this are best done in groups. There are a few types of tests that are important, but not shown here in the interests of brevity. Keep this in mind and know that these results need careful interpretation.
Ok well i had a go at it and found it needs to be about 6.5" deep ?Dose that sound right or close? That's an awful lot smaller than i was expecting. That's a good 10" smaller in depth from standard
Do you guys use gaskets or not?
Now... you are basing your observations upon a test group of a single driver. It would be more useful to compare several drivers off the assembly line. A 37Hz Fs would be at the limits of production tolerances assuming a target 30Hz Fs. If you measured it at low signal levels and especially if the driver wasn't broken in by a drive signal, it could even measure higher and still be within production tolerances.
If you take a group of Extremis drivers, put them in our suggested enclosures and measure the ACTUAL response of the system you will find they vary very little. Why? Because in the acoustic system the suspension is dominated by the enclosure, not the Cms of the driver.
Of course that's true, but what does that have to do with the quoted specs of the driver? What you're saying is true for any driver....
T/S parameters are remarkably accurate at capturing the small signal performance of a driver.Krutke is not "some guy on the Internet"... he's a professional engineer, just as Dan Wiggins is. This is science, not a popularity contest. No need for personal attacks on either person; it adds nothing to the discussion.The reality is that Adire's numbers are suspicious. Take a look at their own posted impedance plot:http://www.adireaudio.com/Home/Images/ExtremisZ.gifNotice how the impedance peak [b ...
Sup guys,I have a question about the cross over in the LCR now.I see the tweeter and the mid are wired backwards. The + goes to the - of the speaker and so on. And the woofers are + to +.My question is i have the 2641 kits aswell but there tweeter and mids are wired the other way. So this would mean that the LCR would be out of phase with the 2641 mains yes?So should i wire the woofers backwards in the LCR and the tweeter and mid + to + - to - ? Just like the 2641's are ?Thanks,Tim.
Hang on, let me put it another way.Should i just connect the finished speaker backwards at the binding posts and leave the cross overs as per the schematic? ( which is exactly the same as what i asked before just doing it an easier way) So they would be in phase with the 2641's then? If i don't the LCR will be out of phase with my 2641 speakers? Or is someone not telling me something and the centre LCR is supposed to be out of phase with the 2641 speakers? Some how i don't ...
Update....Well i just finished building my sealed LCR today Turned out pretty good i think. Just a nice size too.Anyway. I wanted to test my theory as mentioned 5 or 6 posts back about the phase thing.I think i was right. It WAS out of phase with my 2641's I disconnected one of my 2641's and put the LCR in its place and played some music. I could clearly tell it was out of phase with the other speaker. So i reversed the speaker wires at the binding posts on the ...
Timoxx4,...or anyoneHow does the sound compare between a 2641 and an LCR?Thanks,
