Hagclock install
0 Members and 1 Guest are viewing this topic. Read 1300 times.
mcspack
Hagclock install
« on: 31 Jan 2006, 08:52 am »
I have a universal player that I will be building my hagclock into eventually and I am wondering if I can use the can style clock crytal that is on my CDP board as the crystal to build into my hagclock?
thanks
MC
hagtech
    • http://www.hagtech.com
Hagclock install
« Reply #1 on: 31 Jan 2006, 05:33 pm »
Yes, you can usually use the xtal removed from the player as the xtal in HAGCLOCK.  There might be an odd-ball player out there using a series-mode xtal, but I'm not aware of any.  Virtually all are Pierce.  If your circuit looks like what is in the manual, you'll be fine.
jh :)
mcspack
Hagclock install
« Reply #2 on: 31 Jan 2006, 07:14 pm »
thanks EOM
