0 Members and 1 Guest are viewing this topic. Read 3853 times.
Trying to find a way to run a integrated and ht receiver through the same sub system. Diferent input gains would be sweet also. Maybe a pro amp?
The NHT X-2 crossover will do what you want. Just add any acceptable amp and you are good to go.
Quote from: John CaslerThe NHT X-2 crossover will do what you want. Just add any acceptable amp and you are good to go.Excelent, I think thats along the lines of something I'm looking for, how much are they though?
After looking at the NHT site: XLR conects nice, a gain switch good, can this thing drive a pro amp directly?
yet another question,When running a LFE signal into the NHT or similarly equiped plate amps, does the lfe input bypass phase settings? IF your setting distance for the sub in the prossesor, you shoudn't need phase adjustments on the crossovere or plate amp. The nht looks to have really good phase options for running out of an integrated.
I was wondering if the X-2 put out enough voltage for pro amp input sensitivity, I've heard some peole have problems with ht gear and pro amps not having similar output/input sensitivity.Off topicI'll have to come visit sometime if you have a showroom, I should be moving to LA soon. Deciding if I want to get a torn pectoral fixed first.
