Bugle Pro
0 Members and 1 Guest are viewing this topic. Read 1293 times.
Bizzie
Bugle Pro
« on: 23 Jan 2006, 09:48 am »
:?: I have finnished my bugle pro kit and it sounds great really makes a difference when playing 78s.
I was wondering if its best to leave it turned on all the time as was recommended by Project for for my Project phono box SE or is it better to only have it turned on when in use.
By the way the bugle beats the Project easily IMHO. :?:
hagtech
    • http://www.hagtech.com
Bugle Pro
« Reply #1 on: 23 Jan 2006, 09:43 pm »
As a solid-state machine, the Bugle doesn't need to be left on.  There are no power stages or anything with much heat, so it comes up to speed pretty quickly.
The CYMBALs, on the other hand, take an entire hour to open up.
jh
