Which Nuforce for my contours ?
0 Members and 1 Guest are viewing this topic. Read 1563 times.
dgotlse
« on: 22 Jan 2006, 09:24 pm »
Hi to you all,
this my first post and please forgive my English from now on.
I'm the proud owner of a pair of Dynaudio Contour 1.4S hooked to a Moon I3.
I'm currently considering buying Nuforce blocks.
Which one should I buy : Ref8 or Ref9?
Thanks for helping.
moray james
    • moray james cables
That depends
« Reply #1 on: 23 Jan 2006, 12:55 am »
If you have the budget then you will be happier with the larger amplifiers. Since the amplifier modules are identical and so will sound much the same. I say much since the bigger amp will swing more volts and supply more current. The larger amp will sound more open effortless and dynamic than the same amp with a smaller supply. So the choice is yours. I would if funds are available opt for the modle 9's. Best regards Moray James.
John Casler
Re: Which Nuforce for my contours ?
« Reply #2 on: 23 Jan 2006, 01:21 am »
Quote from: dgotlse
Hi to you all,
Thanks for helping.
At 85db sensitivity, unless you listen at low levels and nearfeild, you would likely need the Ref9's.
