SPV1 is not getting controlled by my SP1.7
0 Members and 1 Guest are viewing this topic. Read 2258 times.
eddiem67
« on: 22 Jan 2006, 06:55 am »
My SPV1 is no longer responding to my SP1.7 44F software, what gives, it will not power down, switch component, nada...can anyone help me out what I can do to fix this issue.
Yes the cable is connected between the two units.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 22 Jan 2006, 12:53 pm »
I assume it has been working fine in the past?
I assume you tried a re-boot using the power switch on the back of the SP1.7?
james
eddiem67
« Reply #2 on: 22 Jan 2006, 06:07 pm »
Yes and Yes
« Reply #3 on: 23 Jan 2006, 02:37 am »
OK - I will see if I can get an answer for you tomorrow.
james
« Reply #4 on: 23 Jan 2006, 04:05 pm »
Hi eddiem67,
Try removing the power cord from the wall on the SPV1 then replug it in and then rebooting.
Also could be the RS232 to 1/8 phone plug cable could be defective.
james
eddiem67
« Reply #5 on: 25 Jan 2006, 04:38 pm »
Quote from: James Tanner
Hi eddiem67,
james
Ok I unplugged everything, and started form scratch, the SPV1 responds to input switching from the 1.7, but it will not switch from C1 to C2 and vice versa when I switch inputs from DVD to Cable.  Also the unit does not power down when I power down the 1.7.
« Reply #6 on: 25 Jan 2006, 04:44 pm »
Hi Eddie,
Ok - maybe we should try a new cable.
james
eddiem67
« Reply #7 on: 25 Jan 2006, 10:20 pm »
You Got Mail
