Why do recording from the 30's sound thin?
0 Members and 1 Guest are viewing this topic. Read 1530 times.
woodsyi
« on: 22 Jan 2006, 03:01 am »
I love listening to vocals.  I have gone to many live concerts and listened to LPs and CDs to know what vocals should sound like.  When I listen to recordings from the 30's or earlier, I just know that real voices were fuller.  Is there a curve you can put on top of RIAA that willl restore fullness to these voices?
Scott F.
« Reply #1 on: 22 Jan 2006, 04:21 am »
Actually there is. If I remember right, RIAA became accepted by the record companies in 1958.
Heres a link to the Graham Slee Jazz Club. Its the one I use.
http://www.gspaudio.co.uk/preamps/jazzclub.htm
I think Hagerman makes one also along with KAB.
woodsyi
« Reply #2 on: 22 Jan 2006, 04:47 am »
Thank Scott.
I new you had to get different curves for 78's but I didn't know that there were variations in the early LP stage.   I will have to figure out how to add the curves in my analog stage.  May be the Bugle Pro that I have for the 78's will do the trick. :?:
Scott F.
« Reply #3 on: 22 Jan 2006, 02:37 pm »
Hiya Woodsyi
I got to searching and came up with this......
Equalization Curves by Name
                                       Turnover          Rolloff
     AES                             400 Hz  (375)  -12 dB
     FFRR (1949)                 250 Hz            -5 dB
     FFRR (1951)                 300 Hz  (250)  -14 dB
     FFRR (1953)                 450 Hz  (500)  -11 dB (-8.5)
     LP/COL                        500 Hz*          -16 dB
     NAB                             500 Hz            -16 dB
     Orthophonic (RCA)        500 Hz            -11 dB (-8.5)
     629                             629 Hz  (750)
     RIAA                           500 Hz**          -13.7 dB
* modified from NAB: less bass below 150 Hz, requiring about 3dB boost with bass tone control.
** "Very close" to NAB.
Equalization Chart for Pre-1955 LP Records
                                       Turnover          Rolloff
     Angel                              NAB            -12 dB
     Audio Fidelity                   NAB            -16 dB
     Bach Guild (501-529)        NAB            -16 dB
     Bartok 301-304, 309,
       906-920                      629 Hz (500)   -16 dB
     Boston                             COL            -16 dB
     Caedmon 1001-1022      629 Hz (500)   -16 dB
     Capitol                              AES            -12 dB
     Capitol-Cetra                     AES            -12 dB
     Cetra-Soria                       COL            -16 dB
       or                                   AES            -12 dB
     Colosseum                        AES            -12 dB
       or                                   COL            -16 dB
     Columbia                           COL            -16 dB
     Concert Hall                       AES            -12 dB
       or                                    COL            -16 dB
       or (until 1954)                  RIAA           -8.5 dB
     Decca                                 AES            -12 dB
     Decca (until 11/55)              COL            -16 dB
     Decca FFRR (1951)           300 Hz (250)   -14 dB
     Decca FFRR (1953)           450 Hz (500)   -11 dB (-8.5)
     Ducretet-Thomson            450 Hz (500)   -11 dB (-8.5)
     EMS                                   375 Hz         -12 dB
     Epic (until 1954)                   COL            -16 dB
     Esoteric                                AES            -12 dB
     Folkways                              COL            -16 dB
     Haydn Society                       COL            -16 dB
     HMV                                     COL            -16 dB
     London (up to LL-846)        450 Hz (500)   -11 dB (-8.5)
     London International          450 Hz (500)   -11 dB (-8.5)
     Lyrichord                              COL            -16 dB
          or                                    AES            -16 dB
          new:                            629 Hz (750)   -16 dB
     Mercury (until 10/54)              AES            -12 dB
     MGM                                     NAB            -12 dB
     Oceanic                                 COL            -16 dB
     Oiseau-Lyre (until 1954)           COL            -8.5 dB
     Overtone                               NAB            -16 dB
     Polymusic                              NAB            -16 dB
     RCA Victor (until 8/52)            NAB            -12 dB
     Remington                              NAB            -16 dB
     Urania (most)                         COL            -16 dB
     Urania (AES eq)                      AES            -12 dB
     Vanguard (411-22, 6000-18)    COL            -16 dB
     Vox (until 1954)                      COL            -16 dB
     Westminster (before 1956)       NAB            -16 dB
       or                                         AES            -12 dB
Looks like I remembered wrong. It seems they all adorted RIAA in 1955 rather than 58.
I'm pretty sure the Hagerman makes the phono EQ you are looking for in kit form. You might be able to take your existing Bugle and add a selector switch to add a few of the EQ curves above. If I do some more digging, I might be able to come up with a schematic if you want to try the switch.
woodsyi
« Reply #4 on: 22 Jan 2006, 11:30 pm »
Wow,
Great Scott!
Thanks for the infomation and keep digging away.  I have a bunch of early Opera records that I would love to be able to hear fully EQed.
