Bryston B100 - does not turn on this morning
0 Members and 1 Guest are viewing this topic. Read 1798 times.
eril
« on: 21 Jan 2006, 06:33 pm »
I am in New Zealand.
I got my B100  new yesterday.
Sounded fine playing for 5-6 hours.
I turned it off with the remote, then off at the wall last night.
I've tried a different power cord and a different wall outlet to no avail.
What do I do now?
Hogg
« Reply #1 on: 21 Jan 2006, 06:36 pm »
First, check fuses.
                                            Jim
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 21 Jan 2006, 06:37 pm »
Please contact the Bryston Distributor in New Zealand - sounds like it could be an internal fuse.
james
« Reply #3 on: 23 Jan 2006, 05:20 pm »
Hi eril,
OK - there are 2 fuses in the B100.
One is at the back where the power cord goes in - it is a clip and the fuse with holder will pop out.
The other is inside -  right at the front of the unit  in the middle. It is covered with a plastic sheath.
We think one of these fuses is gone.
james
eril
B100 Internal Fuse
« Reply #4 on: 24 Jan 2006, 12:23 am »
Thanks James
It was the internal fuse. All OK now.
I like the B100 more as it burns in - becoming smoother and more open.
I look forward to hearing it in a month or so.
Cheers
