interesting way to make a silient PC
0 Members and 1 Guest are viewing this topic. Read 1607 times.
WerTicus
« on: 17 Jan 2006, 02:20 am »
http://www.tomshardware.com/2006/01/09/strip_out_the_fans/
well damped too, probably could sound better than any other pc for audio purposes, and perhaps the concept could be applied to other hardware, like amplifiers!
Carlman
« Reply #1 on: 17 Jan 2006, 02:34 am »
If you expect the oil smell to be a problem, then you should plan for a top cover right away. However, the heat exchange between the oil liquid and the environment will then be altered.
OK, so you can't hear it but you can smell it!  :lol:
Very cool experiment!  I'm glad someone has the time and inclination to do this sort of stuff.
-C
Folsom
« Reply #2 on: 17 Jan 2006, 06:35 am »
Upgrading or changing some thing inside is a bitch though!
speedcenter
    • http://didnt.doit.wisc.edu/audio
« Reply #3 on: 17 Jan 2006, 09:14 pm »
finally an easy way to make donuts while you're computing :)
craig223
« Reply #4 on: 17 Jan 2006, 09:21 pm »
When you need to work on the PC, just drain off the oil and burn it in your car!  Check out http://www.greasecar.com
