impedance matching Q for Frank
0 Members and 1 Guest are viewing this topic. Read 1745 times.
marvda1
  • freelance reviewer: The Sound Advocate
« on: 16 Jan 2006, 03:38 pm »
hello frank, i have dodd audio tube preamp with an output impedance of <200 ohms, will this be a problem mating with your ss or hybrid amps?
marvin
avahifi
    • http://www.avahifi.com
« Reply #1 on: 16 Jan 2006, 10:31 pm »
No problem, the hybrid Fet Valve Ultra amplfiers have an input impedance of one meg ohm so they are an absolutely easy load for any preamp of any type, size, or design (although ours work best  - - -  crass commercial statement).
Frank Van Alstine.
skrivis
« Reply #2 on: 17 Jan 2006, 08:02 pm »
Quote from: avahifi
Frank Van Alstine.
To answer the other part of the question, the OmegaStar amps should work fine with your preamp too. I have an old Jensen's (AVA) Super PAS and it has no problem driving my OmegaStar amp.
