0 Members and 1 Guest are viewing this topic. Read 3527 times.
The voices do sound better. At one point, I thought that more noise was coming through. However, I think the Ref 9 isn't noisier per se; instead, it's simply amplifying what it gets and there's a lot of noise on the Antiques Roadshow. I thought the voices were really fleshed out well. Unfortunately, I didn't do a "before" and "after" test, so I'm going on just what I heard without such a test. Nonetheless, the voices had clarity that I'm not sure the Bryston/Lexicon gave me. I heard nuances in voices ( ...
Woodsyi, I can easily hook up the Ref 9 to a Larger. In fact, I could perform a pseudo-comparison: I have one working channel on my QSC 3402 and I can hook up one Larger to that, then hook up my other Larger to the Ref 9. I can play music (even mono) and see what happens. I do have a problem with one Larger, though, which is probably a wiring issue (the two drivers are likely wired out of phase). I'll have to fix that first. I have the Ref 9 situated in a perfect spot to do this comparison. If I can't ...
Bob,If ever get a chance would you mind trying the nuforce on your larger? I have been wanting to try them on my largers (it has less power but higher damping ratio than my crown k2).
Dang it John,You are tempting me. I may have to get one to compare. It will have to be later though since I just spent a chunk with you.
