XLR - better sound?
0 Members and 1 Guest are viewing this topic. Read 2288 times.
caleb
XLR - better sound?
« on: 13 Jan 2006, 05:33 am »
Can anyone give me a wiring diagram so that I can take a output from an RCA socket into the XLR input of my 7B SST?
How will the wiring be made?
I am currently using RCA to RCA cables.
Will I hear any sound improvements?
Sebastiaan de Vries
    • http://www.soundevolution.nl
Re: XLR - better sound?
« Reply #1 on: 13 Jan 2006, 09:39 am »
Quote from: caleb
Dear Caleb,
Better use the RCA input, The input stage make this signal differentieel after the opampmodule by a second opamp to invert fase.
If you still want to try, solder the positive side of tha RCA to PIN2 of the XLR. The ground on PIN1. Also make a bridge between PIN1 and PIN3 tot. You short the inverted input to ground with this bridge! This will work.
Good luck,
Bas
Muttondraw
XLR - better sound?
« Reply #2 on: 19 Jan 2006, 12:22 pm »
Schematics are available on the Bryston website, under technical. Follow this link:
http://www.bryston.ca/BrystonSite05/pdfs/SSTAmplifiers/4b+7bSST-SSB-SCH-6_20041013.pdf
