9bsst same as 3bsst
0 Members and 1 Guest are viewing this topic. Read 1801 times.
fld
9bsst same as 3bsst
« on: 13 Jan 2006, 02:30 am »
just wondering whether the amp section of the 9bsst is the same as 3bsst ? many thanks
ec
9bsst same as 3bsst
« Reply #1 on: 13 Jan 2006, 03:06 am »
same basic design but from an older post from James Tanner, if I remember correctly:
The 3B has more available heat sinking thus higher power output.  I believe it has more caps per channel as well.
Godfather
9bsst same as 3bsst
« Reply #2 on: 13 Jan 2006, 07:25 pm »
Nearly the same but not quite.
See this thread:
http://www.audiocircle.com/index.php?topic=22211&highlight=9bsst
Levi
9bsst same as 3bsst
« Reply #3 on: 13 Jan 2006, 08:26 pm »
3BSST is better in 2ch applications compared to a 9BSST used as stereo.  Although, the difference between the 9BSST and 3BSST will be subtle.
fld
9bsst same as 3bsst
« Reply #4 on: 14 Jan 2006, 11:09 am »
Quote from: Levi
many thanks for those reply.
Had a feeling that the 3bsst used in 2 channel should sound a little better than a 9bsst used in a 2 channel.
Levi
9bsst same as 3bsst
« Reply #5 on: 14 Jan 2006, 03:16 pm »
On the other hand, the 9BSST is excellent in home theater applications.  :wink:
Godfather
9bsst same as 3bsst
« Reply #6 on: 14 Jan 2006, 06:42 pm »
Quote from: Levi
And you'll have the option of bi-amping using 4 channels. :)
