0 Members and 1 Guest are viewing this topic. Read 3608 times.
While i'm asking, is it advantageous to use two dpdt (one for each channel) rather than a single 4pdt?
Good question...but I don't know the answer. With small signals, I can't imagine the magnetic fields coupling, so I can only imagine that by using one switch rather than two you are tying the channel signal grounds together. Does this create a loss in channel seperation? Don't know.
This is a relavent thread for me, I'm just finishing a ucd amp where I want two inputs. one for a pre/preo, and one for a two channel pre. I was planning on using a pair of dpdt's, switching both the signal and the ground. Am I asking for problems?Thanks, Ryan
I'm a bit confused and would appreciate anyone's input.It seems to me that switching the hot and ground would help obviate potential ground loops; however, it's been suggested here that tying all of the grounds together is better. This practice seems counterintuitive to me. Is it simply a way of insuring that all components are at the same ground potential? What if one component is improperly grounded?Also, since i'll only be switching between two components, i don't need a multi-way switch, such as ...
