0 Members and 1 Guest are viewing this topic. Read 18122 times.
On another forum there is a sub-forum for gear costing > $20k.A topic was posted asking for opinions on overpriced gear.I posted that I thought Wilson Audio was\is overpriced.I never said they were crap or anything, just overpriced and I honestly feel that way.I've heard X-2s and the WATT\Puppy, properly set up etc.Someone who owns Wilsons took exception, looked at my profile there and gave mea jab with rolleyes because I listed Salk speakers(soon). I don't have them yet so I qualified it. ...
my d**k is bigger than yours....same mentality..........
These are the same type of people that purchase Porsche 930 Slant Nose. They do it because they can. I am in no way knocking the esoteric gear out there and do respect people who can afford and enjoy it. I wrote some words about the difference between Audiophiles and Music lovers (and their systems) but I don't think this is the proper place to post it as I would not want to intrude on Jim's forum. All I can say right now is that being a speaker designer from way back, I agree with the thoughts posted so far
I want a system that does not call to attention itself rather disappear allowing the music to flow. It should be smooth, enjoyable and non-fatiguing over long periods of time. Has a good center image that more than one person can enjoy at one time and most importantly, simply allows the music to get inside of me.
Okay, I feel I have to make a few more statements before responses on my post start coming though.I guess I would take a little exception to the notion that "audiophile" speakers measure well, at least within a narrow window, but "musical" speakers won't. That's probably an overstatement of your position, but it does describe a certain school of thought. I'm fascinated with speaker design both from a technical standpoint and a musical stanpoint. I've spent a good part of my life playing in various orchestras, and listening to them--and to me the whole notion of having Mozart emerge relatively unscathed from an MDF box is a major modern miracle. But how well he emerges depends on solid scientific principles. If a speaker sounds dry and irritating, there is probably something wrong with the power response. On the other hand, if the meaured performance has obvious flaws, you will hear them as colorations, even though you might enjoy some of them--at least some of the time on some music. The real unsettled issue, IMHO, is just where the highs should be voiced. I try to design speakers that can be adjusted (particularly down) in the highs without compromising driver integration and phase relationships. But I have yet to be happy with a design--mine or anyone else's--that has basic flaws in the measurements.
While I have always liked Wilsons, they are over priced. What are the Watt Puppies up to now? 17k? As for speaker measurements, I like them (though I don't know what a power response is). But I think like anything else, they have to be understood to be used. For instance, I'm reading a book called "The Loudspeaker Design Cookbook." In it, the author references a figure and states that the figure obviously indicates an improved transient response (as compared to another close-box design). Darn if ...
