Bugle with split signal grounds
0 Members and 1 Guest are viewing this topic. Read 1184 times.
randallvw
« on: 9 Jan 2006, 06:27 pm »
I need to have the left and right signal grounds independent from the cart to my line stage. Would this be a simple matter of cutting the ground plane (bottom layer of the PCB) down the middle and isolating the earth ground terminal?.
I do use the external PS, but do not join the PS and signal grounds. Would the PS require modifications as well?
hagtech
    • http://www.hagtech.com
« Reply #1 on: 9 Jan 2006, 09:22 pm »
Randall,
No, it is not possible.  The opamps are dual and shared between channels, thus tying together channel supplies and grounds.
I am not aware of any phono stage that runs completely separate supplies and grounds.  Except for mono units.
jh :|
