0 Members and 1 Guest are viewing this topic. Read 2212 times.
I am thinking about putting in a couple of dedicated lines but if I do this I will require extra long power cords, say about 20 feet in length, as the dedicated outlets must be installed across the room from where my system resides? There is no way around this. Currently I have 3 pieces on 1 line. Bryston amp, Hovland preamp and my digital gear is plugged into a small BPT conditioner also on the same line. Installing 2 lines would allow me to drive the preamp and amp on their own lines and leave the digit ...
I would run a couple of lines, but IMO you should keep them on the SAME circuit not different circuits. Wish someone would have told me that when I ran mine. If you run different circuits, it GREATLY increases your risk of ground loop hums. Or you could run one line and multiple outlets to the one line.
Thanks. I actually solved it by just adding another duplex to one of the circuits, so now I have four outlets, and I use the other circuit (one duplex) for things like remote control on pre-amp, which is mechanical and not in signal path, and the battery charger for my turntable, which again is not in any signal path.The next time I have an electrician in though, I will have him move the breaker.
Quote from: MarblesThanks. I actually solved it by just adding another duplex to one of the circuits, so now I have four outlets, and I use the other circuit (one duplex) for things like remote control on pre-amp, which is mechanical and not in signal path, and the battery charger for my turntable, which again is not in any signal path.The next time I have an electrician in though, I will have him move the breaker.Well, if I ever make it out to your 'hood for some reason, I can take care of that for 'ya...
dedicated lines arent a waste even if you use long power cords,first you can never have to many outlets,second a clean line with no other draws -total brain lock on the name but there is way -your electrician runs the new lines along the bottom of the wall and covers them when hes done with a metal piece-doesnt look that bad and would get your outlet were you want them-man i cant get the name off the tip of my tounge-
