major power scare today
0 Members and 1 Guest are viewing this topic. Read 749 times.
rosconey
« on: 7 Jan 2006, 09:42 pm »
for the last month or so my lights in the house would dim once in a while-so i called the power company to check the lines and meter today(early am)-they did and said all was ok- about 1 hour later  i turn on the microwave and all hell brakes loose all the lights in the house start flashing,micros sounds like its going to nuke and im scared as hell,so i run down stairs and turn off the mains  and call my electrician-then climb into the attic to make sure there is no fire up there and start sniffing thru the whole house-
vinny showed up a few hours ago and started to figure out what was happening-then my buddy dave showed up with his friend from the electrical union-took the 2 of them about 5 minutes to figure out it has to be in the meter-they cut the wire lock and pop the meter-
the bottom connector was broken loose(from a ice fall 3 years ago that took the meter out)-they stuck some shims under it and put everything back together- :mrgreen: wtf didnt the power guy notice it-
man o man i was freeking out when it happened-now i just have to get a appointment to get the power shut off and restart so he can replace the piece -
Skynyrd
« Reply #1 on: 8 Jan 2006, 12:36 am »
Rosconey,
What a great story!
The electric company did not notice that you'd cut the meter's wire closure?!  (here in Minnesota, there's a plasic little lock)
Remember that TV show for us consumers  "Fight Back"?  That's you, Rosconey, you're running the show now.
Skynyrd
