0 Members and 1 Guest are viewing this topic. Read 5295 times.
Good to hear! Any plans on getting the CDWG?
P,You asked:QuoteGood to hear! Any plans on getting the CDWG? Yes, this is the type of tweak that I am very interested in, as it is non-invasive. I am very interested on how it will sound in my room (with my gear).Kevin
I will be curious to know what you think of CDWG when you get it. It took some effort to achieve a tonal balance to my liking and I needed external control (i.e. gain control on separate amps) that you won't have since you run yours full way.
John,Thanks for chiming in. What are your thoughs on Woodsyi's concern - that it might be more difficult to incorporate the waveguide if you are running your speakers full-range???Thanks,Kevin
John,I think the 40s may have the most difficult time getting the tonal balance reestablished with CDWG because it has the most reduction in the midrange output (4 panels) and the biggest midwoofer (10"). I am not discouraging anyone to get it. In fact, I love the way mine sound after a bit of effort in retuning and I would recommend it for any 40 owners. I just want them to know that I had some head scratching and hours of adjusting the L-pads, gains on my different amps and putty adjustment to get ...
