iPod - What format should be used for best quality sound?
0 Members and 1 Guest are viewing this topic. Read 1003 times.
ton1313
All,
I am currently using an iPod as my source, running straight into a pair of amps. It sounds great, but certain CD's sound really bad & distort all over the place.
I am currently ripping the songs using the AIFF (I think that is the letters).
I have some MP3's that are at a much lower bit rate & they sound fine.
Any advice would be appreciated.
Folsom
« Reply #1 on: 4 Jan 2006, 10:21 pm »
What size is the Ipod? I would think .wav or mp4 (apple lossless) would be the best choices.
I would rip with EAC if I where to use .wav's. Hell I might even rip with it first then convert to mp4 or some thing.
Are you using a dock or any thing? I thnik some Ipods might even be capable of a digital out?
srb
« Reply #2 on: 4 Jan 2006, 10:26 pm »
AIFF is Apple's uncompressed format and would be equivalent to the PC WAV file.
Either of these should sound much better than the same tune in MP3 or MP4 (Apple's AAC) compressed formats.
There are several "Lossless" formats that work similar to a zip file and can pack into approximately 60% of the size.  (They are not compressed, as all the information is there bit for bit).  Two are Apple's Lossless and FLAC (Free Lossless Audio Codec), however I believe the iPod only supports Apple Lossless.
Are you using the Line Out connection through a dock, rather than the iPod's headphone jack output?
ted_b
« Reply #3 on: 4 Jan 2006, 10:39 pm »
Clean ripping is your first priority.  Use EAC, not iTunes.  Second, the file size depends on the size of your iPod, and the number of times you want to reload it.  Heck, use any lossless format(wav or Aplle Lossless) for best sound, but they're anywhere from 50% to 500% larger than your MP3's.  If that doesn't matter, or if you are willing to reload your iPod with another set of tunes from iTunes, then go for it.  Me, I use my 40gig iPod for portable use only, although with very good phones and a headphone amp.  A 224AAC song is very very close to wav quality for a fraction of the size, but the fidelity may very well show itself on a home system.
And you MUST use the line out from the dock or third party line out accessory.  Using the headphone out will cause distoriton (if iPod is too loud and over driving line input) or hissy (if iPod is not loud enough and not driving line in enough).  Realize that if you are using an iPod shuffle, the line out is a misnomer, it's a headphone out too.
ton1313
« Reply #4 on: 5 Jan 2006, 04:50 pm »
If I use the line out on the dock, the iPod will still have volume control, right?
EAC? I am not familiar with this. Can you explain.
duff138
« Reply #5 on: 5 Jan 2006, 06:41 pm »
Quote from: ton1313
no volume control when using line out
EAC= exact audio copy.  software to extract music from CDs to put on computer or rip to CDR
Folsom
