Thinking of upgrade, but what does the Etesian get me?
0 Members and 1 Guest are viewing this topic. Read 1517 times.
SamA
I'm new to the board and am thinking of upgrading to Odessey's $1500 system. The web site doesn't give me alot of info, but what does the Etesian get me in terms of inputs and headphone possibilities?
Klaus said I'd need a phono pre-amp to run the TT. What other additions could I expect besides a tuner? XM, iPod, cassette/R2R?
Will the Khartago work as well with 4 ohm speakers and 8 ohms?
djbnh
« Reply #1 on: 3 Jan 2006, 10:26 pm »
Re: headphones - you'll need a headphone amp. Etesian does not come with 0.25" jack.
Brian
« Reply #2 on: 3 Jan 2006, 10:38 pm »
Hi
The Etesian is a passive preamp. This means that your can use it for CD, Tuner, Tape-deck, dvd and other equipment that gives out a full signal.
For use with a TT, you need, as Klaus said, a phono-amp/RIAA as the signal of the TT is to low for the Etesian. But this is more or less common to day, as a lot of pre-amps do not have a build-in RIAA (The Tempest DO have a RIAA, but cost a bit more than the Etesian)
It does not have an out for a head-phone, so here you can either take it from you CD or in case of the TT you need an extra headphone-amp. One cheap amp which can do both TT and Headphone is the Bellari which cost around 200$, keeping the total budget within 1700$.
The Khartago do not have any problem with a 4 ohm load.
I hope the above will help you
Brgds.
Brian
SamA
Okay ...
« Reply #3 on: 6 Jan 2006, 12:30 am »
Okay, so I need a separate FM tuner AND a phono pre-amp. No biggie. FM stinks where I live and, besides, XM offers better programming.
So ... it comes down to this  ...
No chance to audition the gear beforehand. Will I get a "leap" in sound quality from my circa 1982 gear? And if not the Epiphanies, perhaps, the Nightingales?
As I joked with Klaus about on the phone, I'm 50. Despite a tremendous 20-year guarantee, this could be the LAST system purchase I make. Will it take me out in style?
rosconey
« Reply #4 on: 6 Jan 2006, 12:44 am »
you will be impressed- your old stuff is about at its limit for life unless you rebuild them,i guess caps last 15-20 years before they degrade-
