Fair Question,
The senstivity follows your initial comment... 84-85db/2.83 volts. It has an 8 ohm nominal sensitivity and a low dcr of 6 ohms. HOWEVER, you should realize the commercial marketing departments commonly embelish their sensitivty ratings.
If you are plannining to build and amplifier, the fairly common @ 60wpc AKSA or ESP amps can use higher voltage rails with the 1801, and push another @ 40 watts. Their "normal" design optimally accomodates 4 ohm speakers, but is not optimal for 8 ohm speakers. Yes, SS amplifiers are built to accomodate loudspeaker impedance too.
As mentioned in my recommended amplifier string, I encourage @60wpc SS or @ 35wpc tubes. The latter is commonly an EL34 push/pull tube amp.
Dave
